How to ID a T5 flywheel?
Old Mar 14, 2013 | 09:46 PM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
I need a flywheel for my project, a T5 swap into a '91 305 car. Going to look at a used flywheel, how do I tell what year /type it is? As far as I know, the one piece rear main engines, 1987-1992, use a different one from the earlier cars, How do I tell them apart?
Old Mar 15, 2013 | 06:59 PM
Re: How to ID a T5 flywheel?
Bolt pattern.
The center hole is about ½" smaller on the 1-pc, and the bolt circle is correspondingly smaller.
The 1-pc units also have the little "bat wing" internal balance weight on them to replace the weight supplied by the non-round 2-pc crank flange.
Old Mar 15, 2013 | 07:09 PM
Car: '91 Firebird
Thank you
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
