t10 question!
Car: 1991 Formula
Engine: 350TBI
t10 question!
Is there an alternative combination yoke/drive shaft that would work with s bw. T10 that's from a 82 fbody?
Re: t10 question!
Not sure about "alternative"...
Easiest one would be, the DS etc. from a 82 F body.
Tell us what you've got and what you want to do with it and maybe we can figure out what you need to get from where you are (or aren't, as the case may be) to where you wish you were.
Car: 1991 Formula
Engine: 350TBI
Re: t10 question!
Just seeing if I can avoid finding that rare dtiveshaft or havinsg one made. Simpl project car with a 383 and a t10 just no drive shaft
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: t10 question!
the '82 t-10 cars used the same driveshaft as the '82 TH200 automatics-standard GM yoke.'82 driveshafts are a little longer than '83-92.
Re: t10 question!
If memory serves, the yoke on the 82 T-10 was NOT the one that was on the 81-back. Instead it's the smaller one, same as all the others in these cars.
Car: `86 SS / `87 SS
Re: t10 question!
If you ended up with a 32 spline T-10, yes a TH400 yoke on an 82 shaft would work:
If you can find the conversion u-joint as needed and:
If you don't try and use one that has an extra long u-joint center to slip-section distance.
beachrodder
Aug 7, 2015 04:27 PM
