how to press on outer pinion bearing?
Old Mar 27, 2013 | 07:26 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Any tips?
Can I use the pinion nut and a sleeve? Maybe a deep socket and a bfh? Don't want to damage the bearing you know.
Old Mar 27, 2013 | 07:54 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Re: how to press on outer pinion bearing?
Oven and freezer? And if I do that should I let tempratures equalize before setting preload?
Old Mar 27, 2013 | 07:58 PM
Pinion nut and yoke
Lube the lip of the seal with some grease first
Old Mar 27, 2013 | 09:12 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Thanks Sofa!
Old Mar 29, 2013 | 04:25 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
I USE A KING SIZE ARBOR PRESS AND STACK UP LOWER CONTROL ARM BUSHING SHELLS ON TOP OF THE PINION BEARING INNER RACE. PUSH ON INNER RACE ONLY OF COURSE.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
