Identifying 4th gear switch for TCC
Old Mar 26, 2013 | 09:47 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
My Transmission is an '85. It is out of the car right now and I am taking off the pan to change the fluid and filter. How can I identify which 4th gear switch I have (normally closed or normally open) with it out of the car and not hooked up to the car. I understand that if it was in the car i could test for continuity.
Is there a visible way to tell?
I need to know so I can wire up my car for torque converter lockup without the ECM.
Old Mar 27, 2013 | 12:57 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Identifying 4th gear switch for TCC
Doesn't need to be anywhere except in your hand
Put a DVM ( Ohm scale ) on it;
If switch has only 1 terminal , then meter between the terminal and the switch body ;
if it has 2 terminals meter between them
https://www.thirdgen.org/forums/carb...c-control.html
Old Mar 27, 2013 | 07:21 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Thanks. I removed the switch just now and will take it to school tomorrow and try to ge tit tested. Just to clarify, I want it to not show anything? As in no circuit?
Old Mar 28, 2013 | 06:22 AM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Okay I hooked it up to a volt meter (best that I can do) to check resistance. I'm getting fluctuations from 2-9 ohms. What do you think it's not very high? Does the presence of resistance mean its normally closed?
Old Mar 28, 2013 | 09:23 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Any body?
Old Mar 29, 2013 | 04:31 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
SOUNDS LIKE ITS NORMALLY CLOSED. BUT WITH DIRTY CONTACTS. SHOULD BE INFINITE FOR OPEN AND EXTREMELY CLOSE TO 0 OHMS FOR CLOSED. (LIKE .ZERO TO .005 OHMS ) CHANGE IT OUT. ITS CHEAP. DOUBLE CHECK THE SCHEMATICS FOR THE TRANSMISSION TO MAKE SURE YOU HAVE THE RIGHT ONE. DONT DO ANYTHING ON ANY CAR WITHOUT THE CORRECT SCHEMATIC.... DISASTER WILL FOLLOW.....ECM DESTRUCTION ETC....
jklein337
Sep 19, 2018 06:23 PM
Dialed_In
Aug 20, 2015 01:45 PM
jbd1969
Aug 17, 2015 07:06 PM
dhonda200
Aug 11, 2015 11:50 PM
