mechinical to electric speedo ?
Old Apr 4, 2013 | 11:43 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
i have a mechinical driven speedo trans in an electric speedo car, ive heard of a censor that you can buy that bolts on to the trans and converts it to electric signals for the car, now the question is any one know where i can find it? a link would be very helpful. i tried searching on 3rdgen and only found speedo gears, and tried searching the web but am finding all sorts of stuff that im reasonable sure isnt what i need.
Old Apr 4, 2013 | 02:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: mechinical to electric speedo ?
Post 7 is correct:
https://www.thirdgen.org/forums/tbi/...cle-speed.html
Old Apr 4, 2013 | 04:34 PM
DARKmj16's Avatar
Engine: 305 tbi
i have a '92 camaro with a '86 t-5. the vss from the auto wouldnt fit and an electric vss for a t-5 is hard to find.
Old Apr 4, 2013 | 09:14 PM
jmd's Avatar
jmd
Yeah, I figured you had an 80 something T5 by your original post.
It's kind of an endless web cross-reference trail when trying to find the right one. The # in posts on here refers to a maker's VSS list; their #, when searched bring up a major mfgr's PN; that PN cross-referenced through Napa gives....
Call Napa and see if a Echlin VSS218 has the o-ring size that's just slightly under 1". You can measure the working length of it against your mechanical speedo bullet & gear. With those two factors alike, it should fit.
And you'll still need the gear to go on it. If your mechanical stuff has a gear on a steel shaft, that will work; removing it is tricky though.
Old Apr 4, 2013 | 11:23 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I used this on my t5, and if it will work for you it is for sale.
GM/Mopar Speedometer Sending Unit:
16 pulse/rev output, Hall-effect
0.104" driver key
Quick disconnect/cable wire harness included
For GM/Mopar transmissions type
This Sensor will fit all transmissions with a 7/8"x18 Thread on the cable output on the transmission. On Muncie Transmissions you will need to remote mount the sensor.
Old Apr 4, 2013 | 11:35 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://tpiparts.net/inc/sdetail/10956/7587
Old Apr 5, 2013 | 11:28 AM
DARKmj16's Avatar
Engine: 305 tbi
thanks guys. vetteoz that is exactly what im talking bout. lol i dont wana pay $85 but need that speedo working.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
TrevinE
Sep 14, 2015 03:20 PM
