Which is the right trans??
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Im going to be doing a 350 build soon, looking for 450hp, but im stuck on transmissions. I may just keep the 700R4, i don't need all the trouble of a manual swap, i wouldn,t know where to start :\.
So what do i need for a trans for under 600hp???
If a manual swap isn't hard, con someone point me in the right direction of doing a manual (probably t5) swap??? Thanks!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Which is the right trans??
In stock form neither of the trans you list is going to last with your "proposed" Hp levels
Check out
http://www.transmissioncenter.net/hi...0r4.htm#Stage3
for what it costs for a T700 built to handle what Hp you think you are going to have
https://www.thirdgen.org/forums/sear...archid=5923722
Check out
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
