Help 700r4 v6 or v8?
Old Apr 20, 2013 | 11:25 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
If anyone can help I would be greatful. I need help decoding my transmission to see if it is for a v6 or v8 engine. I took out a T5 manual and 305 tbi and swapping in a 350 carb and I bought a 700r4 from someone that said it was behind a v8, anyway here is the numbers 14TM151C, MD8, and 8663549. I think the first number means that is 1991 built 151 day of the year at night shift, the second number just means it's 4l60 or 700r4 having trouble with third number,please help someone.
Old Apr 20, 2013 | 11:58 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: Help 700r4 v6 or v8?
Just snap a picture of the bellhousing, that's the fastest way of knowing.
Old Apr 21, 2013 | 12:11 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
What he said. They look very different.
Old Apr 21, 2013 | 01:25 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
if the bellhousing is about 18" across, then it's a V8 trans... if it's closer to a foot across, then it's a V6..
Old Apr 21, 2013 | 01:33 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
V6 bellhousing is more of a trapezoidal shape.
Old Apr 21, 2013 | 02:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://en.wikipedia.org/wiki/List_of_GM_bellhousing_patterns
Old Apr 21, 2013 | 09:00 AM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Here is a pic of bellhousing
Old Apr 21, 2013 | 09:21 AM
V8
Old Apr 21, 2013 | 09:28 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Yep, V8.
Old Apr 21, 2013 | 09:52 AM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Thank you all for the help that was a relief.
Old Apr 21, 2013 | 11:27 AM
morgsie's Avatar
It could have come behind a 4.3L V6...
Old Apr 21, 2013 | 02:25 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
If it was for a 4.3 v6 could you rebuild it like a v8 and have the same internals in it?
Old Apr 21, 2013 | 02:43 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I dont see why not. The guts on a 60* V6 700r4 are almost all exactly the same.
Old Apr 21, 2013 | 08:08 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Thanks for all the help everyone god bless.
Old Apr 21, 2013 | 09:35 PM
Engine: 450HP 355
Transmission: TH350
Does it have the Fbody tailshaft?
Old Apr 21, 2013 | 11:19 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Will have to send a pic tomorrow.
Old Apr 22, 2013 | 03:41 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
here are some pisc of tailshaft not sure about the different sizes of them. If someone can tell me if this is a fbody tailshaft.
Attached Thumbnails Help 700r4 v6 or v8?-100_1710.jpg   Help 700r4 v6 or v8?-100_1711.jpg
Old Apr 24, 2013 | 12:18 PM
morgsie's Avatar
Of course. Valve body calibration (shift points) are most likely different compared to the V8. Clutch stack ups might be different as well.
Old Apr 24, 2013 | 12:23 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Its a f body tailshaft and v6 and v8 the internals are the same
Old Apr 24, 2013 | 01:27 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
usually there's one less friction disc in each clutch pack if it's a v-6, to make it a v-8 you have to change the piston in that drum (to make it shorter) so you can add another friction and steel in that clutch pack.
if you are making more power than stock, I would suggest making it like a v-8.
trans by your code would be a '91 4TM. I am trying to find out what it was in.
are you POSITIVE it is a '4' TM -- an FTM they are telling me is out of firebird or camaro 5.0 -- they don't show a 4TM.....
Old Apr 24, 2013 | 02:08 PM
antoine's Avatar
The internal s are the same v6 or v8 look up rebuild kit it the same.
Old Apr 24, 2013 | 03:54 PM
fasteddi's Avatar
Car: 1991 Camaro RS
The servo, boost valve, and intermet. valve are different. Smaller. At least this is true with 60* 700r4's
I know this because of adding in a shift kit and relizing that every part was too tiny for a trans go's reprograming kit.
Old Apr 24, 2013 | 05:48 PM
greggbruce's Avatar
yes the kits are the same, but you have left over parts for the v6. I have overhauled hundreds of these, the 6's are different than the 8's.
Old Apr 24, 2013 | 06:30 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
My bad, yeah it is a f and not a 4. Thanks it was really dirty and I looked at it wrong
Old Apr 24, 2013 | 06:37 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
This is the best website to do anything with your third gen fbody, because it has the best people, so many bright minds. Can't thank you all enough.
Old Apr 24, 2013 | 06:55 PM
greggbruce's Avatar
SCORE !!! an f body trans for an f body car !!!
Old Apr 24, 2013 | 10:39 PM
Engine: 450HP 355
Transmission: TH350
Yep, not a V6 trans of any kind.
I'd upgrade a few things while you have it out, It's not that bad to do on your own.
I'm putting about 350 HP/300TQ to a V6 700R4, spinning it to 7K RPM and it's taking it like a champ with the street/strip kit from Pro Built Automatics and a 4500 stall.
https://www.700r4l60e.com/store/prod...&cat=52&page=1
Old Apr 25, 2013 | 03:26 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Mines good to go also with the trans go reprogramming kit, vette servo, larger intermediate and boost valve from probuilt. Id bet im right there with deathstar pushing 300+hp and more then that on Tq on a 3k stall up to 6500 rpms. And the ole 700r works fine.
Just read up and be patient. It was my first time working on the trans department and it was flustrating at times.
Old Apr 26, 2013 | 01:36 AM
antoine's Avatar
http://www.700r4l60e.com/forum/viewtopic.php?f=6&t=108
Old Apr 26, 2013 | 01:55 AM
project89's Avatar
i was going to say when i was building my v6 transmissions to live behind my turbocharged 3.1 that i never had any leftover parts
i used the tci master race rebuild kits on mine
Old Apr 26, 2013 | 04:43 AM
fasteddi's Avatar
Car: 1991 Camaro RS
I didnt have left over parts, just parts that the insturctions said dont use. So I had to buy different parts so that I had ones that were "ok' to use with the kit.
Old Apr 26, 2013 | 07:00 PM
greggbruce's Avatar
that link talks about an "E" transmission.....
I've spent 17 years in a GM dealership building transmissions, I can't count the number of v-6 trannies that have one less clutch in each drum, and I have the stacks of extra clutches to prove it. I also cannot count the number of pistons I have changed to convert v-6 to v-8.
it's really no big deal...
Old Apr 26, 2013 | 07:01 PM
greggbruce's Avatar
LOL -- so they really weren't 'left over'?
Old Apr 26, 2013 | 08:16 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
It would be my first rebuild on my own. I've helped and watched someone rebuild a 700r4 but just back to stock specs. I haven't decided if I want to tackle it by myself or not yet.
Old Apr 26, 2013 | 08:51 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Before I can even think about rebuilding the transmission got to rebuild my 350 carb engine.
Old Apr 26, 2013 | 09:42 PM
morgsie's Avatar
greg, it would be cool to have a list of what the 3 letter code corresponds to what car it came out of. I know YMD is Corvette, and that's about it. Can you share your list (if you have one)?
And yes the F-body valve body is one of the better performance ones. My '89 Caprice cop car had an almost identical VB to what came out of the F-body's. Shift valves stamped: M (1-2), 10 (2-3), 0 (3-4)
Old Apr 26, 2013 | 10:34 PM
greggbruce's Avatar
I prodded a friend at the dealer to dig up some stuff.... I had a small list (like only a couple years) once upon a time, but seem to have misplaced it, sorry. If it turns up, I will post it.
I know a couple by memory from my dealership days: TAD is a baby blazer (but 4L60E)
and a KCD is a full size truck (4L60E)
Old Apr 26, 2013 | 10:45 PM
greggbruce's Avatar
I've taught a couple of people, not too awful difficult, just like a puzzle that you can't leave any parts out of--- neat part is, you get to start with the puzzle already assembled, and take it apart ....
Old Apr 27, 2013 | 12:40 AM
morgsie's Avatar
Would be cool if someone kept a running list of known codes... But as long as you know what shift valves to look for you can easily locate the right valve body from a used parts supplier.
I come from a pretty broad mechanical background (cars, helicopters and now elevators), but was very satisfying (and frustrating at times) rebuilding my 700R4 and having it work (so far). Learning curve was pretty steep having only changed filters, fluid, and a few TV cables and lockup solenoids in the past. Very rewarding and would have no problem rebuilding another automatic in the future.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
