TCI lockup to brake switch question
Old Apr 28, 2013 | 09:11 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
Which wire would I splice into for the brake switch? Grey, grey/black or brown? I already deleted the ECM and I am going to use the vacuum switch with the brake switch. The two wire setup is a ground for pin D and pin A goes to the brake switch I think. I think this will make it lock up pretty much like it did before the delete, eg. No toggle switch.
Old Apr 29, 2013 | 01:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TCI lockup to brake switch question
Won't make any difference.
All you need is power from the switch on one terminal at the trans and a ground on the other terminal
If all you did was take the ECM out then you should still have the factory ( usually purple ) wire from the brake switch to the trans
so all you have to deal with is the other side of the TCC solenoid at the trans
read
https://www.thirdgen.org/forums/carb...c-control.html
Old Apr 29, 2013 | 08:22 AM
Car: 1984 Z28 T-TOP
I think the purple comes from after the ECM. But, I'll check. I am leaving the rest alone, but wasn't sure which wire was the one after the switch rather than before it.
Old Apr 30, 2013 | 07:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As shown in the link
Old Apr 30, 2013 | 07:45 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I think the purple comes from the ECM. But, I'll check. .
Nothing comes FROM the ECM
As shown in the TCC link I posted for you above
12V supply on the purple from the brake switch ; tan / blk control wire TO the ECM to operate the lockup solenoid
Old May 1, 2013 | 11:07 AM
Car: 1984 Z28 T-TOP
My purple wire is on the curise control release brake switch. Does that sound right? Should still work I think.
BTW, Thanks for the link.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
