another tcc question
Old May 5, 2013 | 07:56 AM
cmm7v3's Avatar
Car: 92 Camaro RS
Engine: 1JZ-GTE
Transmission: R154
I am in the middle of doing a 305-355 swap and will be ditching the tbi for the fast ez efi. I will still be keeping the stock ecm to run the gauges in the car, will the ecm still be able to control the lock up while not managing the engine or will I need to run one of the available or make my own tcc lock up kit.
Old May 5, 2013 | 08:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: another tcc question
Originally Posted by cmm7v3
I will still be keeping the stock ecm to run the gauges.
Gauges run direct off the sensors on the engine ( or the coil in the case of the tacho ) ; not the ECM
The ECM would have to have all the same inputs it does stock
Just install a 4th gear pressure switch in the trans valve body; anytime trans goes into 4th the convertor will lockup.
https://www.thirdgen.org/forums/carb...c-control.html
No need for any extra or manual switches
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
