flywheel ?
Old May 9, 2013 | 09:48 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
flywheel ?
have an 86 fb with a 2.8,5speed.externaly balanced motor.If I put a new crank that dosnt have counter weights like the factory one.will my weighted flywheel on the drive line now work with any none balanced crank kit.How do I get the thing balanced if I cant mix new with old.
Old May 12, 2013 | 12:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: flywheel ?
will my weighted flywheel on the drive line now work with any non balanced crank kit.
Probably not
You have to spend $$ to get it rebalanced which raises the question
Why would you want to use a crank with a difference balance style to your stock setup???????
Old May 12, 2013 | 02:08 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: flywheel ?
Not to mention weighted 2.8 flywheels seem to be impossible to find anywhere but the junkyard these days if you ever needed a replacement.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
