Turbo build. Stock ring and pinion hold?
Old May 25, 2013 | 01:49 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Transmission: TH 350 with Hughes 3500 stall.
Axle/Gears: Moser Axles and 4.10 gear.
I'm building a blow through 5.3 LM7 in my 85 IROC. I have a brand new Richmond 4.10 gear for it because I was gonna go with an old school 383. But I'm needing to go with a higher gear to be able to build boost. My car has a stock 3.42 gear and I was wondering how it would hold up?
Old May 25, 2013 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Turbo build. Stock ring and pinion hold?
May hold all you can throw at it. May break on the street on first pull. Cant tell
My personal 10 bolt stock gears has held 800 hp and mid 9 sec et's. others break on stock ls1 cars... Automatic trans help soften the load but theres still only so much it can take
Old May 25, 2013 | 04:19 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
This is gonna be a street car. Not gonna take it to the track very often.
Old May 25, 2013 | 04:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It should be ok
Old May 26, 2013 | 01:47 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
That's what I was thinking but I just don't wanna take a chance in messing up my locker or something. I could handle getting a different ring and pinion if it goes out.
Old May 26, 2013 | 03:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
See alot of ring failures but sometimes the carrier can crack. Launches tend to hurt much more than acceleration while already moving
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
hectre13
Aug 26, 2015 08:17 AM
LT1Formula
Aug 20, 2015 09:36 PM
