What rear is this?
Car: 84 Z-28
Engine: 355 4 bolt main
Transmission: 700 R4
Axle/Gears: Posi 3.73
What rear is this?
Need help to identify a rearend. The code is 6HS it is a factory disc brake rear and I was told a 3.73 posi. But I cant verify that because nothing I find has that code. An the last ear I find a 3.73 posi is 86 any help would be great.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What rear is this?
It's old enough that it could be anything. The code only tells you what was originally inside. Pull the cover off and count the teeth. The oil probably needs to be replaced anyway.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
