stripped governor gear th400
Old Jun 2, 2013 | 01:17 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
im in the tear down stage of my th400 rebuild. the problem i had was it felt like in second and third it was slipping. first and reverse felt fine. i found the governor gear stripped out. could this be the only issue? i thought it had mostly to do with shifting? this car has been rebuilt previously by a racing shop and they put the manual/auto type valve body and most of the time i shift it manually anyway
i went with the atsg manual and it seems lacking on the trouble shooting specs and inspection. its more of a cook book do this-do this-do this, etc.
i went with this kit
http://www.summitracing.com/parts/bmm-21041/overview/
Old Jun 4, 2013 | 05:46 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
Re: stripped governor gear th400
hoping someone knew if it would shift manually to 2 and 3 with the bad governor?
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
fasteddi
Sep 10, 2015 09:32 AM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
