1st time t-5 rebuild
Old Jun 4, 2013 | 08:46 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
hey guys this is gona be my 1st time ever rebuilding a trans, and its a nwc t-5. I have the kits coming for a complete overhaul and I have the rebuild manual how ever the manual isn't specific on what tools I will need.
so the question is what tools will I need for this rebuild?
basic sockets/wrenchs (ofc)
something to measure end play (micrometer or caliber? idk the difference)
anything else? did a search and didn't find much, 1 said there was a sticky about it but there is no sticky... maybe there should be? I can give the link to the free download of the rebuild manual if needed, lol why pay 3 bucks on ebay for the same thing, or 15 for a printed one, if you could find it.
Old Jun 4, 2013 | 09:43 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 1st time t-5 rebuild
A GOOD set of strong snap ring pliers.
RTV
STEEL cluster support plate with shims (double check it fits NWC t5s)
Torx bits
First link if you google "T5 rebuild manual"
http://www.allfordmustangs.com/techa...uildmanual.pdf
Old Jun 4, 2013 | 09:52 AM
DARKmj16's Avatar
Engine: 305 tbi
ok snap ring pliers torx bits and rtv I have but this steel cluster plate... can you explain some more?(sounds like something that's added, isn't it?)
btw I said I have the manual, which ironicly is the same one in that link, just straight from tremec instead of a mustang forum.
Old Jun 4, 2013 | 10:00 AM
midias's Avatar
Get some punches to drive out roll pins.
Print the manual, set it by the toilet and read it every time you sit down.
This is a good plate. I would email them and double check to see if it fits NWC T5s
http://www.ebay.com/itm/World-Class-...-/221192729558
It upgrades the factory stamp steel piece.
http://www.5speeds.com/t5.htm
Don't forget the camera take lots of pics for reassembly
Old Jun 4, 2013 | 02:14 PM
DARKmj16's Avatar
Engine: 305 tbi
aaa I see, thx for that tip.
any other tools? ive read somewhere on line something about using gear pullers to pull the gear cluster off and an arbor press to press in bearing caps...
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
hokis
Aug 9, 2015 03:57 PM
