building junkyard 9" brake setup info
Old Jun 4, 2013 | 11:37 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I am wondering for all of those who tackled this how did you do the rear brakes? I want to run 4th gen brakes but am unsure how it will work when trying mount them with the different axle flanges.
Thanks,
Chas
Old Jun 4, 2013 | 12:03 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: building junkyard 9" brake setup info
Just answered my own question. Take a look at the link, the rotors are drilled for both bolt patterns. Looks like I don't need the 4th gen stuff.
http://www.jegs.com/i/Right+Stuff/96...Fe1AMgodxkUAFQ
Old Jun 4, 2013 | 12:28 PM
big gear head's Avatar
You can use Moser 7900FM housing ends and have the axle hang out set to the 4th gen amount and use the 4th gen parts on the 9 inch.
Old Jun 5, 2013 | 10:39 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Ok so a little on the Right Stuff ZDCRD05 - Right Stuff Ford 9'' Rear Disc Brake Conversions. The brake pads are from a 79 El Dorado and the rotors are modified 84 Corvette rotors. I am debating which route I want to go. Not sure which would be easiest. I might be just cutting down the axle tubes and re-welding. tough decision.
Old Jun 5, 2013 | 05:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Or you can do what I did.
https://www.thirdgen.org/forums/brak...ferential.html
Old Jun 6, 2013 | 07:32 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Originally Posted by AlkyIROC
I like that. A lot cheaper than buying one of those kits although they aren't priced too bad. It all just depends on what your time is worth.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Eric-86sc
Apr 3, 2016 03:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
