Can I keep my stock Delco Moraine rear disc brakes with a 28 spline axle?
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Never thought if this one before.....can someone pipe in?
Chuck
Chuck
Re: Can I keep my stock Delco Moraine rear disc brakes with a 28 spline axle?
Thanks !
I just got off the phone with Jegs and they said it should work fine as well...I asked him the the hub for a 26 spline is the same as a 28 and he said yee... So hopefully it'll turn out ok.... Thanks again!
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
once,using a stock axle originally from a drum rear on a disc rear,had to turn down a little in a lathe the outer diameter of the flange as the drum axle would not fit into the "hat"area of the rotor-probably not a problem with aftermarket axles though.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
novaderrik
Aug 10, 2015 12:44 PM
