High shift points. NEED HELP!!!
I have a 91 camaro rs with a 700r4 transmission. From 1st to 2nd it revs high and then it kicks hard into gear. 2nd to D is smoother but doesnt shift till about 3500 rms, and from D to OD it doesnt like to shift till 4000. I already changed the fluid, changed the filter, flushed it and put transfix in it and the problem still exist. I drove it around for a little while the other day and after about 20 min it was perfect, but when i got in it this morning it started doing it again. Can anyone help me plz???
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: High shift points. NEED HELP!!!
Try the obvious 1st , the item that controls the shifts
http://www.jakesperformance.com/TV_C...etup_Info.html
http://sethirdgen.org/tvcable.htm
if that doesn't work .your governor in the trans may be sticking / faulty
Thanks, Ill check it out and see what happens.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
