95 Aluminum Driveshaft U joint for 9 Bolt
Old Jun 13, 2013 | 03:15 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Anyone know a part number of a u joint for an aluminum driveshaft to mount up to my 9 bolt?
seems the MOOG number is 234 for the 95 which i guess should be fine for the front, but what baout the rear?
My steel shaft swapped right over without doing anything to the u joints when i swapped to the 9 bolt but assume the aluminum is different.
Old Jun 16, 2013 | 02:20 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: 95 Aluminum Driveshaft U joint for 9 Bolt
do you have the 3rd gen shaft or the 4th gen?
NAPA U joints for JG1 RPO alum drive shaft - third gen 372(R) 369(F)
NAPA U joint for 4th gen alum shaft 534G
Old Jun 16, 2013 | 05:04 PM
insomniac's Avatar
Engine: 5.7 L98
4 gen but need to mate it to a 9 bolt
Old Jun 16, 2013 | 06:07 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Shouldn't be an issue, bolt it up and go. Direct fit.
Irocguy01
Sep 28, 2015 02:03 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
Navy8125
Aug 22, 2015 07:13 PM
MENINBLK
Aug 5, 2015 11:58 PM
