need help with 700r4
Car: 82z28
Axle/Gears: posi/ stock gears
Switched my carb out about a week ago now when it is a wide open throttle at any speed it downshifts 3 times and its almost like it gets stuck between first and second. I am pretty sure if im going 50 it shouldnt try to downshift to first. Someone told me that i need to buy a throttle valve corection kit does anyone know what i should look for
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: need help with 700r4
Keeps the TV cable geometry in correct alignment.
Look at Jegs or Summit for the right part.
PM me an email or phone #
I'll send a pic of a Holley geometry corrector.
Edelbrock is very similar in design but length & angle are different, therefore carb specific
Car: 82z28
Oh alright will do i appreciate the help, i have no idea how long they ran it like this so im thinkin i might do a rebuild and throw in a shift kit. I also thought about swapping to a turbo 400 would that be a good idea or?
Car: '87 Camaro
Not sending for some odd reason!!
Link--
https://www.thirdgen.org/forums/carb...-question.html
post #6
The " L " shaped thing attached to the carb throttle arm.
Hope this helps!!
( edit )
Third pic
Link--
post #6
Hope this helps!!
( edit )
Third pic
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
