Lockup question
Old Jun 18, 2013 | 09:31 PM
Golfvette's Avatar
Car: 87 Iroc Camaro
Engine: 350 Vortec TPI
Transmission: T56 Magnum
Axle/Gears: 10 Bolt 3:73
Lockup question
Ive searched this website for a few months now to try to figure out why my transmission won't luck up. My Engine runs at 2600 rpm at 60 mph. One test I've found to do is to connect a test light to A and F at the aldl. The light should stay on with ignition on and turn off when car reaches about 30 mph which my car does. My question is after about 30 mph the light turns off until I let off the gass pedal then it will turn back on, is this normal? Is lockup connected to the tps sensor?
Thanks in advance
Old Jun 18, 2013 | 10:09 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Lockup question
Yes, converter lock up is based off of min/max tps settings, mph and a few other parameters in your ECM.
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
