88 Camaro Speedsensor
Old Jun 21, 2013 | 02:40 PM
Spenc247's Avatar
Does anyone know where i might find a Spend sensor for an 88 Camaro 5.0L V8? Apparently autozone discontinued the part from its catalog
Old Jun 21, 2013 | 08:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 88 Camaro Speedsensor
the speedo cable drive for the trans or the VSS in the dash?
https://www.thirdgen.org/forums/elec...cle-speed.html
https://www.thirdgen.org/forums/post...498-post2.html
Old Jun 21, 2013 | 10:19 PM
Spenc247's Avatar
Its the one that mounts on the transmission and controls the shifts and gas consumption, here's a link to the exact part at autozone but it's discontinued http://m.autozone.com/autozone-mobil...Speed%20sensor
Old Jun 21, 2013 | 10:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What problems are you having?
Has nothing to do with the shifts , in the trans it only controls the convertor lockup function
If you have shifting problem , the VSS is not the cause
Old Jun 21, 2013 | 11:04 PM
Spenc247's Avatar
My check engine light reads code 24 and my car shifts hard into drive hard regularly but shifts fine after that point
Old Jun 22, 2013 | 12:56 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Check the TV cable adjustment
http://sethirdgen.org/tvcable.htm
Have you checked the purple / yellow wires back to the VSS to confirm they are good and that the VSS itself is faulty ?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
