Summit Transmission?
Old Jun 30, 2013 | 02:41 PM
Chevyman454bbc's Avatar
Car: 1989 Camaro RS Hard Top
Engine: 305 Bored .30 over
Axle/Gears: Stock
Im tired of all the problems with my old 700r4 which is probobly about to bite the dust anyhow. Been eyeballing the SUM-700300 from Summit its a turbo 350 trans. Heres the link http://www.summitracing.com/parts/sum-700300
Has anyone used this transmission, if so any advice or input on the matter and what can i expect from it. For example is it going to lag when i shift manual stuff like that and is it worth the money after all u cant really beat a transmission for 660.00 Any help would be appriciated. Thank you
Old Jun 30, 2013 | 04:30 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Re: Summit Transmission?
350's are easy to build, only 3 speed though, if not an issue, go for it (fuel mileage drops). My understanding is TC is different, so factor that in, cross member will need to be modded, 350 is shorter than a 700 (driveshaft shortening?), speedo drive may cost you a few bucks. May be cheaper to spend a little more and get a 700.
found= There are some th350's with a long tailshaft that match length of the 700, therefore negating driveshaft mod
350 has narrower gear spread too
http://www.700r4.com/faq/ratiocmp.shtml
Old Jun 30, 2013 | 04:34 PM
Axle/Gears: Stock
Originally Posted by danclemts
350's are easy to build, only 3 speed though, if not an issue, go for it. My understanding is TC is different, so factor that in, cross member will need to be modded, 350 is shorter than a 700 (driveshaft shortening?), speedo drive may cost you a few bucks. May be cheaper to spend a little more and get a 700.
TC?
Old Jun 30, 2013 | 04:39 PM
danclemts's Avatar
TC= torque converter, srry
Old Jun 30, 2013 | 04:44 PM
Axle/Gears: Stock
Lol okay sorry i should have been able to figure that out. Im not used to all the abriviations
Old Jun 30, 2013 | 04:45 PM
danclemts's Avatar
https://www.thirdgen.org/forums/engi...r4-tranny.html maybe?
Old Jun 30, 2013 | 04:52 PM
Axle/Gears: Stock
For me its not the overdrive im looking for, my main use for the car will be drag racing but ill also drive the car on the street and to work and stuff but wont be driving highway so its not needed. My biggest beef with the 700 s the setup. The tv cable and all that. I just want to get rid of that all together so thats my reasoning for going with the 350. I was just posting to see What i would have to do for the swap(which uve answered,thank you) And what the new transmission would be like as far as lag ect...
Old Jun 30, 2013 | 05:28 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i went with a th400 but same difference, i wish i had just built my 700 instead of trading it for the 400. they all have to be built to handle any power anyway, and when you are on the road you dont know how much you appreciate od until you lose it. especially if you are going to race it and probably will end up with steeper gears
Old Jun 30, 2013 | 08:51 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
My dealings with trannies is this buy a decent prebuilt trans with a warranty. I've rebuilt my 700r4 twice from dumb issues now I have to buy another trans because my case is too whooped to rebuild and now I'm getting a 700r4 prebuilt 2 yr warranty for 500$
Old Jul 2, 2013 | 05:28 AM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
I had the summit transmission in my car for a couple years. It shifted firm and I was very happy with the way it performed. I had a longer driveshaft made and I had to make some minor modifications to the cross member. I also purchased a kit from b&m to mount the torque arm. I have swapped to a t56. I missed having overdrive.
Old Jul 2, 2013 | 02:12 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Just curious; what old person in your life told you the TH350 would be trouble free in comparison and suddenly solve all your problems? There's quite a difference in first gear (3.06 you have now versus 2.52) and OD (.70 * rear gear with lockup versus 1.00 * rear gear without lockup) So if the converter were similar, the car will be slower. And if the converter is a high-stall, it's going to run hotter. Not that a cooler is a bad idea.
If you're going to castrate the car, at least make it easy on yourself. Get a 9" tailhousing TH350. Replace the long tailhousing with a spacer (http://www.bulkpart.com/2/product/7Q-35B.html ) and the 700-R4 tailhousing. No driveshaft change. No torque arm change.
We'll all know who to pass. The guy whose engine is SCREAMING in the slow lane, flipping through the $1 bills he's counting. Thinking he saved some money by cheaping out on the transmission cost, but costing himself more in the long run.
Get a good 700-R4, get the TV cable adjusted correctly and be able to enjoy the car everywhere (not just the track) and the fuel mileage.
Don't get me wrong; I know it's frustrating when a major repair is looming over your head like a bunch of clouds. I just got a new HVAC unit on our house and I hated the feeling the old one was going to go out. But for your car to truly do everything you want it to do, going back 40 years and removing a gear is never the answer.
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
