9 bolt questions
Car: 91 Camaro RS
Engine: 305 TPI conversion.
9 bolt questions
I decided to drop in a 9 bolt 3.27 gears disc rear, from an 87 t/a. I had a 10 bolt gu5 g80 which had needed pinion bearings replaced. I put up that rear for now for a possible future rebuild, or strip out to sell. still on the fence about this one.
does the 9 bolt posi take the same gear oil as the ten bolt posi?
one caliper seems seized. can I switch mine from the ten to the nine bolt? they were new.
are the ebrake cables identical?
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
