Help Blew Up 9 bolt!!!
Old Jul 26, 2013 | 01:44 AM
chrisvanguitar5's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 L98
Transmission: 700 r4
3.27 ratio. not to sure what happened but I blew up my 9 bolt, of course it has to be the most ridiculous differential to deal with. Any suggestions, I have done a fair bit of research but I am hoping to get some more ideas. Honestly probably try and rebuild the diff so if you have idea's on that it would be much appreciated!!!!
Chris
Old Jul 26, 2013 | 02:37 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Help Blew Up 9 bolt!!!
Depends on how you blew it up, but a lot of times the posi cones wear out and the backlash on the internal spider gears gets all screwed up and causes them to break. if the cones are worn you can buy new ones.... they will need a little machine work, but they are available (Online in north america) if you know where to look.
But at least consider a different diff. I love my 9-bolt but it had remarkably in tact cones when I bought it.
If you've got to replace gears and a whole bunch of internal parts, you're better off just getting a different diff. It's up to you whether you want to get another 9-bolt. Just be aware for 9-bolts that cone condition is everything.
Old Jul 26, 2013 | 07:05 AM
big gear head's Avatar
What parts did you break?
Old Jul 27, 2013 | 07:22 PM
Engine: 5.7 L98
Hey, the carrier is heat scored, the cones are worn down, axles are goo, spyder gears done, bearings are still good to, I found a reconditioned 28 spline 3.27 ratio 9 bolt 3 series carrier from 9bolt.com for 500 Canadian as our dollar is higher than the Australian. Anyone ordered or had any experience with 9 bolt.com?
Old Jul 28, 2013 | 12:39 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Got a rebuilt carrier from them no problem. Not as much space in the window as the pic from infernalvortex though. Shipping from Australia was like $144.00 U.S. iirc. Ringpinion.com has quality parts and rebuild kits. Autozone has bearings and wheel seals.
Old Jul 29, 2013 | 12:48 PM
Engine: 5.7 L98
ill probably go with 9bolt.com
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
angel2794
Sep 8, 2015 06:22 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
