rear axle oil change
Car: 1989 & 1990 RS V8 TBI
Engine: 305 5.0 L
I am going to change my rear axle oil for the first time. I have never done it before, it sounds like it is fairly easy. However I was wondering if anyone has any tips for me who has done it before. I have a 89 RS 305 TBI.
Re: rear axle oil change
If it has a standaed differential then use any good GL4 or GL5 80W90 or 75W90 gear oil. If it has the Auburn differential then be sure to get 2 bottles of the GM oil additive and put it in the rear end before the oil goes in, or put them in the first bottle of oil.
Engine: 305 5.0 L
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Remove the fill plug before you remove the cover.
I've heard of stories where guys had removed the cover only to find out they can't get the fill plug off. Now they're stuck with an empty differential.
Transmission: 5-Speed Manual
When you remove the cover to drain the oil you will be able to see the differential. If it only has 4 gears inside it and nothing else then it's a standard differential. If it has 5 springs in it then it's the Auburn.
Hardest part will be getting the fill plug out.
Start there: BEFORE removing the cover. It kinda SUX to let your fluid all out, put the cover back on, then discover that you have no way to put fluid back IN.
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
I used Royal Purple with the additive already in it..
Also bought a new fill cap and while I had that diff cover off I painted it and it looks nice..
.... Supreme Member
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
having been THERE before. you can fill it thru the vent opening. if you cant remove the fill plug. just sayin
Engine: 305 5.0 L
Engine: 305 5.0 L
A standard differential only has 4 gears and a shaft inside it. There are no clutches, cones or springs. The Auburn will have 5 springs and 2 preload plates along with the 4 gears and shaft. If it's a Gov Lock then it will have a governor, clutches and 4 gears and shaft.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Will royal purple's gear oil with additive work with 3.73 posi with motive GM gears?
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
