View Poll Results: Drive or Overdrive for city driving
Drive Only!
0%
Overdrive Only!
100.00%
Voters: 5. You may not vote on this poll
700r4: Drive or overdrive: What do you drive in?
Old Aug 9, 2013 | 09:15 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
When you are city driving (under 70km Canada), what do you usually drive in?
DRIVE or OVERDRIVE and what are your reasoning's?
What are the PRO's and CON's do selecting only OVERDRIVE? (As i've done for 14 years but recently started leaving it in drive unless I'm wanting to go over 70KM in which I switch to OD to get the RPM's down).
Old Aug 9, 2013 | 10:06 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 700r4: Drive or overdrive: What do you drive in?
For the vast majority of everyday driving you can leave it in OD and if it's all set up right it should drop into whatever gear is appropriate even in city driving.
Old Aug 9, 2013 | 03:28 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Yeah same here.. 700R4 rebuilt to the hilt and I leave it in OD unless I'm racing. My "D" has rougher shifts so when I race street or track I put it in D. (OD doesn't engage in full throttle anyway)
Old Aug 9, 2013 | 03:31 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I think it's completely dependant on the rear end gear inside the car I'm driving. I've owned too many ThirdGens to count over the last couple decades and each one was different from the last.
With a 3.08 or 2.77's I'll used 3rd for just about all driving except for driving on an Interstate Highway. When driving around town or on State highways I'll leave the shifter in 3rd with those gear ratios.
With cars that have a 3.23 gear or numerically higher gear my normal driving habit is to leave it in 4th MOST of the time. 3.23 cars are left in 3rd a lot and up-shifted on State highways sometimes ( driving for miles and mile of non stop rolling ) but 3.42 and 3.73 cars rev pretty high with an automatic and I find it's better to keep them in Overdrive & let the tranny do it's own thing almost all the time.
Just my !!
Old Aug 17, 2013 | 07:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If your axle gearing is matched to your cam, and your tune is really close to perfect, there's no reason you can't run around at 830 RPM at 30 MPH in OD with no problems. I know, I did it with a carbureted 350 for several months. That was a 3.08:1 axle with a stock "3896929" cam, BTW.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
