Preparing the 700R4 for autocross
Old Aug 24, 2013 | 12:43 AM
david_351's Avatar
Hey all, I recently bought a 1987 L98 IROC which I am going to build into a dedicated autocross car. I plan to have it ready for the start of next season. I will be rebuilding the transmission using the best parts I can while staying legal in whichever class I wind up choosing. Of course I will be adding a massive Transmission cooler, and manually shifting the car. Now, I read an article years ago in Camaro Performers or Chevy High Performance or something, I likely still have the magazine, but it was about a paddle shift kit for the third gens with the 700r4. I've tried finding the company, Retrotek,but they seem to have vanished. Does anyone know of anyone else who makes a paddle shift kit? How well would this work in an autocross scenario do you figure?
Thanks,
Dave
Old Aug 24, 2013 | 07:15 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Preparing the 700R4 for autocross
Paddle-shift requires 4L60E. 700R-4 gives the better option of a full-manual valve body.
Old Aug 24, 2013 | 11:01 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
What have people been using for autocross?
Old Aug 25, 2013 | 03:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by david_351
I am going to build into a dedicated autocross car. manually shifting the car.
In that case you just install a a quality shift kit that allows full manual shifts ; up and down with engine braking
You should be working backwards from your typical top run speed / revs and optimizing your diff ratio to get best use of the T700 gearing.
The 3.07 1st gear does not let a TPI wind out very far
Old Aug 25, 2013 | 08:28 AM
cosmick's Avatar
Originally Posted by vetteoz
The 3.07 1st gear
That's 3.059:1, and this looks to me like the right application for a TH350 swap.
Old Aug 25, 2013 | 07:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by cosmick
That's 3.059:1
3.07 differentiates it enough from the much taller 2.52 and 2.48 1st gears found in the TH350 and 400
Old Aug 26, 2013 | 10:11 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
I used a stock 700r4. Just throw it in 2 and leave it there.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
