How many bolts in a 97 Camaro dif?
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
What was the number of bolts in a 97 Camaro differential? I think the gear ratio is 3.42:1.
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: How many bolts in a 97 Camaro dif?
all 82-02 F-bodies had 9 or 10 bolt rear ends. More common to find a 4th gen rear with 3.42's. However they are no stronger than the third gen 28 spline units.
Also 4th gen rears are wider by around 1 5/8's PER side.
Jay
Jay
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
No 9-bolts after 1990. Only 28-spline, 7.625" 10-bolts, except '92 Firehawks got Dana 44.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
If you are referring to the number of cover bolts the answer is 10, all 4th gen rears are 10 bolts as well as most 3rd gen rears except for the aussie 9 bolts found in some 90 and earlier models. At some point the ring gear side went from 7.5 in to 7.625 in, pretty sure all 4th gen units came equipped with the larger ring gear, not that it makes much difference, both bolt up to the same carriers. What is it you are trying to determine? Also is it a factory posi unit or just an open differential?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
10 ring gear bolts
4 differential bearing cap bolts
1 cross pin retaining bolt
10 cover bolts
so 25..
10 cover bolts
so 25..
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
