Rear end swap
Old Sep 8, 2013 | 01:26 PM
mfoge5's Avatar
Rear end swap
If I swap rear ends from a 92 RS to a 95 SS what wopuld I need in parts and what would I need to change. the 92 is 5 speed drum and the 95 is 6 speed disk.
Old Sep 10, 2013 | 11:48 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Rear end swap
You'll need a pair of 4th gen wheels, and you'll need to change the proportioning valve, plus a lot of little detail pieces.
Old Sep 11, 2013 | 07:53 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Rear end swap
be aware the 95 is 4 inches wider.great for using corvette wheels.
Old Sep 12, 2013 | 05:55 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Rear end swap
And then if you want the same wheels on the front, you will have to run a 2" spacer.
Several other threads on here about the 4th gen rearend swap. Like Atilla said you will need to change the proportion valve to one for disk/disk. If you dont the rear brakes will just barely hold. Everything will bolt right in, parking brake cables is the only part that can be tricky.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
