1350 Yolk, 12 bolt to 700 R4 drive shaft length
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I am swapping in a Moser 12 bolt with a 1350 yolk. Its going to a 700-r4.
Anyone know what the correct drive shaft length will be?
Also what HP will the stock aluminum shaft handle.. I'm up around 675 fwhp and 675 lb/ft torque
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 1350 Yolk, 12 bolt to 700 R4 drive shaft length
Stock aluminum shafts are very weak. Don't expect it to last.
Correct driveshaft length....
Install diff
Install slip yoke into transmission all the way then pull it back out 1"
Measure distance from center of driveshaft u-joint to center of diff u-joint
That's the correct length driveshaft required for YOUR car.
Install diff
Car: 1987 GTA
got it thanks!
Car: `86 SS / `87 SS
I've seen a stock third-gen alum. shaft handle a 3500lb 4 speed Rat car that ran 10.80s.
A 4th gen thin-wall shaft, I wouldn't expect to do that.
Car: 1987 GTA
mine will be about 11.1-11.3, but its a little heavier...we will find out.
luvofjah
Sep 26, 2015 08:28 PM
