Mechanical speedo troubles!
Old Sep 24, 2013 | 05:26 PM
MeanFbirdT/A's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: LG4 305
Transmission: Borg-Warner T5
Hey everyone, I have an 80MPH speedo and odometer connected to a T-5 that doesn't work. Basically I did the trick where I connected a drill to the cable to see if that was the issue. What happened when I did that was the odometer worked but the speedo did not. The odometer/speedo doesn't work when the car is being driven. However I put the drill in reverse and the speedo moved back about an inch(below 0) but other than that nothing works. Only the odometer on the drill trick. What is wrong here? Is it a combination of the speedo/driven gear. Please help!
Old Sep 25, 2013 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Mechanical speedo troubles!
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
mrbird
Oct 20, 2015 03:43 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
Lmancha96
Sep 25, 2015 08:11 PM
