700R problems--its baaaaaaack!
Old Sep 25, 2013 | 07:12 PM
2firebirdpals's Avatar
well gang- the problem is back. I had put the TA away out of frustration because I could NOT get to the governor gear to inspect it. No darn room under the car and not able to reach the governor cap. Darn GM devils. But I backed the car out and warmed her up and ran around the block reaching 1st-2nd and 3 gear"D". Feeling good-- but wait-- THERES MORE-- But Today its the same old stuff. STUCK in 1st- Stuck in First- Darn it. What is wrong with this 700R Automatic?? Why would it work 2 days ago and NOW it wont get out of 1st. stuck at 8 mph I guess- because the Speedo NOW suddenly does Not work, Is there a connection here? No speedometer and stuck in 1st gear?? please help. john
Old Sep 25, 2013 | 09:28 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 700R problems--its baaaaaaack!
3 things I learned about this very thing that may be the cause. #1 TV cable damaged/incorrect part/mis adjusted.#2governor gear is busted/gov. has debris sticking it.#3 there is debris sticking the valves in the valve body. you ARE facing a rebuild. but try a can of "seafoam trans tune". it works wonders sometimes
Old Sep 25, 2013 | 11:03 PM
Thanks--- I have a bottle of Lucas Transmission additive - should I try it? I heard bad stuff can happen when using Lucas though ....... Has Trans Medic by GUNK been helpful in these cases..... Anyway- should I first remove some tranny fluid before adding any Trans Additive?? Is the SEAFOAM safe to use???? thanks again.
Old Sep 26, 2013 | 07:13 AM
Car: 86 IROC
Engine: 5.0 TPI
as a rule,dont use lucas trans stuff.just dump a can of seafoam trans tune in and go (or try to)
Old Sep 26, 2013 | 05:31 PM
Thanks -- I called pep boys and they have it- will def give it a try and let you know. john from long island
Old Sep 28, 2013 | 06:48 PM
I put in just half a bottle of SEAFOAM and it W-O-R-K-S. It did the job. I guess that it freed up a sticking 1-2 shift valve. Sooooo Can I expect this good news to last??? Or am I still staring down a Rebuild in the near future?
Old Sep 29, 2013 | 12:54 AM
Car: 86 IROC
Engine: 5.0 TPI
I got another 650 miles out of mine using the "sea foam trans tune". but it is usually only a temporary fix to a permanent problem
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Ratchet
Dec 7, 2001 09:34 AM
tiffosi
Feb 19, 2001 01:28 AM
Metallica383
Oct 1, 2000 10:24 PM
