Best TH400 yoke
Old Sep 26, 2013 | 05:34 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Best TH400 yoke
Looking for the correct yoke to go on my TH400. Motor is a 406ci procharged sbc. Power around 7-800hp.
Im confused on whether I need a cast one or forged one?
Car will be mainly street use with occasional racing
Old Sep 26, 2013 | 06:32 AM
Re: Best TH400 yoke
Never seen or heard of a "cast" yoke. Which is not to say, necessarily, that there isn't such a thing; no doubt, if somebody could figure out a way to make a yoke-shaped object by that process and sell it for almost-yoke money to somebody that either didn't care if it lasted past backing it out of the shop or just wanted the cheeeeeeeeeepest thing they could find that said "yoke" on the box, it's probably been done.
That said, a stock one would be fine, if it fits your drive shaft; especially if you're not drag racing with really sticky slicks and a trans brake leaving at 6500 RPM or something. Alternatively, there's a handful of people that supply fairly decent ones in the $80 - 125 range that should do fine for your declared application, if you can't find one in a boneyard.
Old Sep 26, 2013 | 06:36 AM
Car: '92 RS Camaro
Transmission: TH400
Re: Best TH400 yoke
The cast thing is a bit confusing, as Jegs list most of their yokes like this. Although the Moser site says machined. I was thinking of the TY700
Old Sep 26, 2013 | 06:54 AM
Re: Best TH400 yoke
Should be fine...
Old Sep 26, 2013 | 07:43 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Best TH400 yoke
Call Denny's driveshaft, they'll guide you in the right direction.
http://www.dennysdriveshaft.com
Old Sep 26, 2013 | 08:04 AM
Car: '92 RS Camaro
Transmission: TH400
Re: Best TH400 yoke
I reckon Dennys is the place, good prices and very good information
Old Sep 26, 2013 | 08:08 AM
Jonesyfxr's Avatar
Re: Best TH400 yoke
I'm lucky, they're only like 20 minutes from me. When I get my 79 together they're gonna do the driveshaft for it.
Also, lifetime labor on their driveshafts!
Old Sep 26, 2013 | 08:07 PM
Re: Best TH400 yoke
Well they're like 4000 miles from the OP.
I've got a drive shaft place right down the street, there's Inland Empire out in So Cal, etc.; not necessarily much help across the pond.
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Sep 29, 2015 10:18 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
nichoulas83Z454
Feb 4, 2001 11:15 PM
