Gen 4 Aluminum Driveshaft on Gen 3?
Can a Gen 4 Aluminum Driveshaft be used on a Gen 3 T-5? Is the yoke different? Length different? The U-Joint has the same part number for both Gen 3 & 4 so if the yoke is different, can the yoke from the Gen 3 be installed on the Gen 4 driveshaft? Talking with Lingenfelter, they sell an aluminum driveshaft for a 1990-2002 Camaro. They claim there is a difference before 1990, although unfortunately the person did not know off hand what that difference was. Knowledgeable insight would be appreciated.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Gen 4 Aluminum Driveshaft on Gen 3?
The shafts are 3/4 " or so shorter but for justfine
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I don't see why it wouldn't work it's a 26 spline output shaft and I believe it's the same length. I had a stock 4th gen DS in my car for a little bit tell my first launch at the track shredded it to pieces. They are known to be kind of weak as I found out later... Make sure you get something aftermarket.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The swap has been done many, many times. Should you require more info, the search function will be helpful.
Best of luck,
JamesC
Best of luck,
JamesC
ambainb
Apr 25, 2016 09:21 PM
