Measurements needed
Old Oct 11, 2013 | 02:40 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Measurements needed
I am getting ready to start mocking up my engine/transmission swap and I need a few measurements. I am planning on putting in an M49 (4th gen T5) behind a turbo 3800 and I need to make sure they are the same length and mount the same. I can make a custom transmission crossmember, but if I don't have to I don't want to. I know the driveshafts are the same from 4th to 3rd gen, so that leads me to believe I will be safe. I am more concerned with transmission mount location. Below is what I am looking for.
Overall length of the 3rd gen T5 (from input shaft back would be nice, but if you could give me from bellhousing back that will work as well)
Distance from tip of input shaft to transmission mount (again input would be nice, but if not from bellhousing will work)
Distance from motor mount to crossmember mounting bolts (left to center and right to center)
This would be greatly appreciated.
Old Oct 11, 2013 | 03:15 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: Measurements needed
One more measurement needed, tailshaft to axle. Thanks guys.
89GTAOz
May 16, 2020 09:31 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
