TH400 Kickdown
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
TH400 Kickdown
Can someone explain how this particular kickdown works?
http://www.summitracing.com/parts/lo...00ht/overview/
It goes from the throttle cable to that little box, but it doesn't look like the box hooks to the tranny anywhere.
Or can someone reccomend a TH400 kickdown for me?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TH400 Kickdown
"Notes: This is an electric kickdown kit.
Stock the TH400 has a elec kickdown with a switch on the accel pedal or throttle linkage
see
http://www.chevelles.com/forums/show...72&postcount=1
see
Re: TH400 Kickdown
It's nothing more than a fancy looking cable operated remote switch. the wires come out of the machined aluminum box, the box bolts to the tranny pan rail and the wire to the kickdown connector and a ground.
Car: 1984 Trans Am
Engine: 355
Re: TH400 Kickdown
Thanks guys. I knew I needed an electrical kickdown, I was confused because the box didn't look like it had any electrical connections though.
Twin_Turbo is that your car? If it is, how did this setup work for you? Could you show some pics of the throttle linkage?
Re: TH400 Kickdown
No, I just googled the image. I wouldn't be caught dead with anything pink on my car
Car: 82 Z28
Transmission: T400
Re: TH400 Kickdown
There are plenty of cheap DIY options , all you need is a micro switch on the throttle or pedal linkage ( hidden under the dash if you are worried about appearances ) that closes when you go WOT
darwinprice
17
Oct 11, 2015 11:51 PM
mike ghoul
Sep 23, 2000 01:32 AM
