Transmission Mount Plate?
Old Oct 23, 2013 | 06:48 PM
nateg's Avatar
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
Hi everyone, I am currently in the process of pulling my engine and tranny out of my 89 IROC and I have run into an issue with the transmission mount. It is a 700R4 Tranny with the 350 TPI engine and on top of the mount there is a plate that bolts onto the tranny along with the mount. This plate however has been snapped on the two extensions that go up to bolt on to the transmission portion (Miracle I haven't felt or heard anything banging to notify me of this). However, I have called around trying to find this plate and have had absolutely zero luck and was wondering if anyone knows where I may find this little guy.
Old Oct 24, 2013 | 01:15 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Transmission Mount Plate?
Not sure that I understand what piece is snapped,.... Can you post a pic ??
Old Oct 24, 2013 | 07:29 AM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
Here are a couple pictures that I took this morning. It isn't the entire mount, just the little plate of angle iron on the top of it.
Attached Thumbnails Transmission Mount Plate?-img_20131024_082328_923.jpg   Transmission Mount Plate?-img_20131024_082246_144.jpg
Old Oct 24, 2013 | 06:33 PM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
Scratch this thread, my new 700R4 does not have a need for this plate. I believe the old transmission had the plate made at home because it does not have the mount holes on the bottom! Thanks for the effort everyone!
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
