my SGI-5A is being a big PITA!
Old Nov 5, 2013 | 08:16 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
So I finally got some time and figured I would finalize some wiring and get this speedometer calibrated.
It was a little low so I decided to up the calibration to get the speedometer corrected. No dice. I followed the directions and either the speedometer would get a little slower or ALOT slower. I just need to speed it up.
I went 5 MPH low at 60 to practically nothing. This is making me think theres an issue with the way it's hooked up. I'm using OUT3, not having interference problems, with one leg of the speedo grounded and the other to SIG IN before the buffer box.
Any input?
Old Nov 5, 2013 | 09:08 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: my SGI-5A is being a big PITA!
had the same problem with my first t56 scott hansen changed the vss pluse width in my prom so no signal box for me
Old Nov 12, 2013 | 12:43 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I am running the sg1 5c. Only thing I had to play with was the switch settings. Wonder what the difference is from the a to the c models
Old Nov 12, 2013 | 11:20 PM
dhirocz's Avatar
I think the c uses the dip switches to get you close then you up or down it to the right speed. The A model has nothing but a bunch of dip switches.
To update, I finally got it calibrated OK after experimenting with it for what seemed like forever. Problem now is, I have interference at idle, so I have to order a noise suppressor inline with the power in to the box...
Old Nov 13, 2013 | 11:05 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I used to have the A model with all the dip switches, now I went to the new C model but I hooked it up different. I decided to remove the yellow buffer all together and use all the wires for the SGI-5C, works great and no more bouncing needle I used to get the odd time. Plus when you remove the buffer box all your wires are right there for power/ground and the hook ups.
Old Aug 2, 2014 | 08:13 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Reviving an old thread but do you remember the wiring configuration? Also, I didn't think a GTA would have the buffer being TPI? Regardless, this is exactly what I'm doing with the C model but can't get it to calibrate...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
