9 bolt rear end help
Old Nov 17, 2013 | 09:36 PM
T-rock's Avatar
Car: 1987 camaro iroc
Transmission: 5 speed borg warner
Axle/Gears: 3.45
I am in the process of restoring my 87 iroc and I had someone take the 9 bolt out of the car and clean it up and he took off rear cover and he found a bolt that was chewed up and broken into 3 pieces.The bolt came out of the carrier case,its the smaller bolt,i believe a 7/16 head.So far everything looks okay,no damage on the ring gear,gonna tear it apart.Where can I get these bolts from,does anybody carry them?Thanks
Old Nov 18, 2013 | 07:05 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: 9 bolt rear end help
They are right hand thread, fine thread, not sure of the pitch. You can take a good one to someplace like Sears hardware and match it up with a thread gauge, then find a grade 8 replacement. UNLESS you are talking about the ring gear bolts (around the outside) then try ringpinion.com (Randy's ring & pinion).
Old Nov 18, 2013 | 07:30 AM
big gear head's Avatar
Randy's Ring & Pinion has them. I had to get a set several years ago. You can also get them from another differential. I have an old 2 series differential with a 2.77 gear on it that might make a good donor.
Old Nov 18, 2013 | 09:06 PM
T-rock's Avatar
Axle/Gears: 3.45
Thanks guys,i will check into finding the bolt,it is a 8 mm head and thread is 1.25 fine,i just found out that the bolt had snapped off inside the thread.So I'm gonna have to get it out,i don't understand how this happened,is this a common problem?
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
