I need opinions on selecting rear ends!!!
Old Nov 18, 2013 | 12:03 AM
joshfgilmer's Avatar
Car: 1992 Camaro RS
Engine: 305 tbi for now (SLOW)
Transmission: factory auto
Hey guys. I have gotten a little farther on my 92 third gen project. I have completed the front suspension. Went to a dual cylinder manual brake system, UMI K member swap, UMI complete front suspension, Big Brake upgrade, 19" wheels, UMI sub frame connectors, and roll cage.
I have selected a used viper v10 t56 combo as my power plant choice.
I need a budget minded rear end choice. This is going to be a fun for me car not a race car except for maybe an amateur track weekend someday. Life has started to creep up on me so my build $$$ seem to keep dropping.
What can I do for a solid rear end choice that won't bounce the back of its foundation?
Old Nov 18, 2013 | 12:13 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: I need opinions on selecting rear ends!!!
if you want a 5000 dollar engine/trans, a 12 bolt or ford nine inch conversion housing from the aftermarket should be affordable to you.
Old Nov 18, 2013 | 06:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Ford nine with aluminun center and trutrac diff.
Old Nov 18, 2013 | 07:28 AM
big gear head's Avatar
Don't spens a ton of money on th eengine/transmission and then try to go cheap on the rear end. A 9 inch or 12 bolt should be fine. Moser, Strange, Currie and Mark Williams make some good stuff. I think Quick Performance also makes one.
Old Nov 18, 2013 | 10:51 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Putting in a roll cage and not racing the car? why?
That's a lot of work if you don't need it. I am in the midst of a cage install and it's a big job.
As for a rear diff, I went with a quick performance ford 9".
A thought for you, but keep the stock diff! I know this sounds stupid, but go till it blows! I had my stock diff down to a 11.0 @ 125mph! With a handful of low 1.5* 60fts.
It'll take you a while to get up to that power level.
Old Nov 18, 2013 | 11:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Try to start with a rearend a lil smaller than what you normally like, esp if you plan to keep her, it will get a lil bigger as the years go by.
Wait, we talking about what I think we are or am I off target a bit here? hehe
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
