700R4 Slipping?
Old Nov 18, 2013 | 09:59 AM
TipTricky's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
700R4 Slipping?
I just picked up a 91 camaro with a l98 and a 700r4 off craigslist and the guy says it has a bad tranny. He said started with not having reverse and now no forward either. Is there something the could cause it other than it just being toast?
Old Nov 18, 2013 | 05:26 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 700R4 Slipping?
Pull the pan, see if there is debris in the fluid but when it's that bad, no.
$670.00 for a rebuild kit from Dana at Probuilt in California.
$800 for a new Vigilante Torque Converter
Rebulid it yourself or spnd $400 for a shop to do it if you do the instal. Around $650 with the removal/install since you supply the parts and you've got a kicking transimssion that will support 600+hp and is fun to drive!
Or you can buy a built transmission tha twill do the same thing for around $2500 and then it still needs to be installed.
Old Nov 18, 2013 | 09:38 PM
TipTricky's Avatar
Re: 700R4 Slipping?
I dont plan to build that much power for a few years its going to be my daily driver and i commute a decent ways. Ill pull the pan thursday thats my next night off. Im going to be doing alot to the car thursday haha
Old Nov 18, 2013 | 11:50 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 700R4 Slipping?
Check the fluid level?
Old Nov 19, 2013 | 12:00 AM
TipTricky's Avatar
Re: 700R4 Slipping?
I have not checked it for level but i checked to see if it was matalicy, brown or burnt smelling and seems normal
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
