cross member??
Old Nov 18, 2013 | 07:35 PM
86camaro454's Avatar
cross member??
i bought a 86 camaro striped getting ready to be a drag car no cross member in it. im putting a 350 with a th350 what cars should i look for a cross member in (v6-v8 firebird-trans am) what i seen its just a flat plate could i make one?? (i have metal in the shop with a welder and a drill press) help would be nice
Old Nov 18, 2013 | 07:56 PM
Re: cross member??
Not too hard to make, really. Needs to be more than a flat plate; even the weenie factory bit of nothing, has stiffening ribs bent into it along the edges.
Only stock one that will fit, is out of a 82 Camaro or Firebird.
Probably not worth trying to chase one down.
Take the torque arm into account in your fabbing plans; won't work without that. Mounting it to the crossmember instead of the transmission (which is difficult at best on a 350) is definitely the way to go.
Alternatively, you can buy an already tested, proven, experienced setup, from any number of sources. Check the board sponsors on this page. Spohn and UMI have packaged solutions; Founders might; there may well be others. No matter how cheeeeeeeeeeeep it looks like it is to fab one up, ONE failure will cost more than buying a tested, proven, known-effective one from somebody that's been there and done that already.
Old Nov 18, 2013 | 09:21 PM
Re: cross member??
http://www.ebay.com/itm/BMR-TCC018R-...3e94db&vxp=mtr
like that or is there something cheaper??
Old Nov 19, 2013 | 06:26 AM
Re: cross member??
Couldn't say about "cheaper"; when I'm buying parts, somehow, "cheap" doesn't seem to be an attribute I consciously seek out or find desirable. I prefer "good".
But yes, that is the right kind of thing, if you want to retain the stock stamped-rubber torque arm.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Pac J
May 17, 2020 10:44 AM
LT1Formula
Oct 8, 2015 08:34 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
