Reverse lock out T-56,, best way to hook it up
Old Dec 4, 2013 | 07:27 AM
irocdis's Avatar
I hooked up my reverse lockout yesterday on T-56 like must people do to your Brake pedal, but I found out the hard way that's not the best spot for it.
I ended up grinding reverse as I was down shifting from 6th to 5th on the brake when this guy cut me off.
Can the reverse lock out be hooked up to the VSS? So it only lets reverse in when it see's no movement?
Old Dec 4, 2013 | 11:32 AM
irocdis's Avatar
Re: Reverse lock out T-56,, best way to hook it up
I think this will do the trick..
http://www.dakotadigital.com/index.c...prd_zm_460.jpg
Its a automatic door lock actuator, and it triggers off the VSS, and it can be set to trigger as low as 7mph.
I will flip the single with a relay and lock out reverse when the car is moving....................when the car is standing still it will be open.
Old Dec 4, 2013 | 10:30 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Many use the Samoco box
http://www.samocoind.com/T56MODULE.html
Old Dec 5, 2013 | 03:02 AM
semiller26's Avatar
Car: 1986 Trans Am
Originally Posted by LilSki
I used one. It works great and it easily hides under the center console for a clean install.
Old Dec 6, 2013 | 06:58 AM
irocdis's Avatar
Samoco box does look like an easier install. Thanks
Old Dec 6, 2013 | 11:35 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I plan to go the Samoco route as well when I install the T56 into my 'bird. I constantly forgot to press the brake when I'd go to back the Iroc out of my garage (had lockout wired to brake as well). Plus, it'll eliminate the chances of grinding like you experienced.
GTAman
Jul 3, 2024 07:29 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
tonys91rs
Oct 10, 2015 03:31 PM
Denricci22
Sep 18, 2015 09:02 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
