4L60E
Old Dec 7, 2013 | 02:58 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
4L60E
I have recently acquired a 4L60E transmission and I wanted to know if anyone had any objections to putting it in my 82 Z with a 350. Also if there are no objections, does anyone know where I can get a drive shaft to fit and a crossmember?
Old Dec 7, 2013 | 06:08 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: 4L60E
I've been searching all day and cant find anything.
Old Dec 7, 2013 | 06:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 4L60E
Is same trans as the T700 auto fitted stock in most years
4L60E transmission wanted to know if anyone had any objections
Fits just like a stock trans ; only problem is you need a $1000 aftermarket controller ( or a LT1 / LS1 PCM )
to operate it seeing it is fully ELECTRONIC operation
Old Dec 8, 2013 | 01:06 AM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: 4L60E
I was going to use TCI's EZ TCU controller. So would my driveshaft from the th200c work with it? Any suggestions on crossmember? Hawksthirdgen has one but it says 84-92 and mines an 82
Old Dec 8, 2013 | 03:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 4L60E
Any suggestions on crossmember? ... it says 84-92 and mines an 82
Simple
So go to a junkyard and get the DS and crossmember from a 84 - 92 factory auto car that came with a T700.
Google works
http://www.tciauto.com/tc/trans-dim
Compare the dimensions / trans mount locations and see if you can work it out yourself
Old Dec 8, 2013 | 10:45 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
Re: 4L60E
u can sell your origanal DS and crossmember to help fund your upgrade. They are highly desirable for those who want a th350 swap
Old Dec 9, 2013 | 11:41 AM
jonarotz's Avatar
Car: 91 Z28
Re: 4L60E
If you're looking for a controller
https://www.thirdgen.org/forums/engi...ontroller.html
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Nervous2
Oct 8, 2015 10:53 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
f-bodyz28
Sep 2, 2015 05:03 PM
