700r4 break in?
Old Jan 19, 2014 | 02:52 PM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
700r4 break in?
Hello everyone,
I recently cleaned up my 700r4 trans with a TCI shift kit, 2/4 servo, and a 2400 stall converter. I put approx. 1.5 litres of trans fluid in the converter before installing it into the trans. I made sure it was properly seated. I have put in approx. 6 litres of trans fluid into the trans itself. Is there anything I need to do during initial start to properly break-in the trans? I know about running through the gears and checking the fluid level etc, anything else?
Thanks!
Old Jan 20, 2014 | 02:53 AM
Pro Built Automatics's Avatar
Re: 700r4 break in?
Did you rebuild the transmission? Or just install the valve body kit?
Old Jan 23, 2014 | 05:36 PM
neilb's Avatar
Re: 700r4 break in?
I installed just the valve body kit servo and new converter, still the original clutches and bands.
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
