1987 lt rear diff questions!!!
Old Jan 26, 2014 | 01:48 PM
mattimus13's Avatar
Car: 87' camaro LT, 58' apache
the rear end in my 87 has gotten quite sloppy lately and i decided to change the spider gears in hopes that it would clean up the slop. however after ordering new spiders and attempting to install them i realized the new ones are smaller and have less teeth. i measured the ring gear and it measures too 8.5 not 7.5\625 like it should however the housing looks like the factory 7.5 camaro housing and the axles are 26 spline like they should be
is i possible some one could jammed a 8.5 carrier in a 7.5 housing?
Old Jan 26, 2014 | 02:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 1987 lt rear diff questions!!!
How many bolts are on the diff cover. You may have a Borg Warner 9 bolt. 9 bolt and 10 bolt parts are not interchangeable. They are 2 completely different diffs although they share the same mounting points to install in a third gen.
There's also a possibility that you have an aftermarket, over the counter, Dana 44. If the rear cover is smooth, it's a 10 bolt. If it has a rubber fill plug, it's a 9 bolt. If it has a metal fill plug then you have a rare Dana 44 which will have a 8.5" ring gear. It wasn't installed in the car from the factory but at the time, could be ordered directly from GM and replaced.
Old Jan 26, 2014 | 02:19 PM
big gear head's Avatar
26 spline axles were only used in the 7.5/7.6 10 bolt rear end. You can NOT put 8.5 parts in the 7.5 rear end. There are at least 3 different sets of differential gears that were used in the 7.5/7.6 standard differentials. Your '87 will have the 7.6 rear end with the larger 26 spline differential gears. The gears that you got are for the older 7.5 rear end.
Old Jan 26, 2014 | 02:22 PM
mattimus13's Avatar
no its definitely a 10 bolt rear end
Old Jan 26, 2014 | 02:41 PM
mattimus13's Avatar
so the only answer is that i miss measured the ring gear...
Old Jan 26, 2014 | 05:06 PM
Yes.
I've probably got several used sets of those gears.
Vintageracer
Jan 10, 2020 05:33 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
