PLEASE HELP!!!! need help on t56 identification
Car: 1985 iroc z
Engine: 350 tpi
Transmission: t56
Axle/Gears: 323 rear
I have a t56 I'm trying to find out exactly what it is. Magnum, slip-shift and such things.. the # on the tag has ...12550647....13-86-009....k2962...h67839....stamped on case is 13-86-065-902 and 13-86-066-904f....thanks for any help I get
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: PLEASE HELP!!!! need help on t56 identification
the 1386-009 code tells me that its a 94-95 lt1 trans. The k2962 code says however it was built 10/29/96 2nd shift. Either way it will have the same ratios and tq rating. Hope this helps you out.
Car: `86 SS / `87 SS
Yep. H is a revision & 67839 is serial.
Could be a warranty replacement build.
I don't know why they wouldn't go straight to using the 96-97 13-86-016 for warranty.
bigjay89gta
Oct 15, 2015 08:04 AM
