Shrink hole on sep.plate tips?
Old Feb 9, 2014 | 03:45 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Going to shink a hole in my trans sep.plate from 1mm to 0.6mm
1. Use a TIG weld to melt the hole and then redrill it
2. "hammer" it closed and redrill it
theese two options feels unsafe since drill with a 0.6mm drill through a steel plate doesnt sound like a good idea...
3. make the hole bigger ( 2-3mm ) and countersink it on both sides with a 4-5mm drill then fill it with a softer mtrl and then drill it sounds better.
What should I fill it with?
- tin is easy but will it hold?
- al. sound better but how do I melt it or do I just hammer it out? ( dont have a AC/DC TIG )
any tips? before I start
Old Feb 9, 2014 | 08:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Shrink hole on sep.plate tips?
Trans-Go supplies aluminum plugs to fill holes. It is as you mentioned, counter sink each side a little, place plate on flat hard surface, gently mash plug with small hammer to fill.
As you only need to close up the hole a little, may be able to use a ball peen hammer and tap around the edge of the hole. That will displace metal into the hole making it smaller.
RBob.
Old Feb 9, 2014 | 09:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
RBob.
thx.......
after testing on another plate
I took the TIG and welded it (20amps +added very little mtrl ) then redrilled the hole.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
