2002 Silverado 4l60e help needed
Old Mar 10, 2014 | 09:38 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Sorry guys know its not an F bod but my DD and Im stuck
In OD occasionally when leaving a light it does this bucking/jerking type thing for a split second then stops, shifts normally and operates fine other than that
In "3" never does it.
Fluid doesnt look burnt has about 40k on it.
Is this something some of you techies have experienced what was the fix?
My experience with autos is ltd to installing shift kits in the old T350/400 trannies but not a bad wrench.
Its my DD and dont have the coin for yet another trans.
Already had 4 in it. This was a brand new crate GM trans/converter has about 80k on it total
Thanks!
Old Mar 10, 2014 | 06:31 PM
Re: 2002 Silverado 4l60e help needed
Doesn't sound like a trans problem...
Sounds more like fuel delivery.
Old Mar 10, 2014 | 10:50 PM
Axle/Gears: 4.11
Interesting Ill check the fuel pressure and the TPS I hear can affect things.
Had something similar happen yrs ago the shift points were getting screwy changing the fuel filter solved it
Old Apr 1, 2014 | 09:02 PM
Axle/Gears: 4.11
Against my better judgement I had the trans power flushed, filter changed and threw a bottle of Lucas in it.
Been 3 weeks? All seems Ok so far no shuddering maybe a solenoid had some dirt stuck in it
I noticed the converter doesnt unlock in OD soon as it normally does. Truck pings some maybe my FP is low shoot just put a FP in it 2 yrs ago
Tell ya if it werent for the electronics Id put a T400 in it or sell it and buy something older with no smog and a Qjet.
Old Apr 2, 2014 | 08:35 PM
Parrydise7's Avatar
I had a similar problem with my 2003. When I told the dealer about it they downloaded software updates.
Good luck.
xkingcodex
Feb 12, 2020 07:43 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
