Need some advice on Th350
Old Mar 27, 2014 | 04:38 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
Hello
Ive been searching the board for a few weeks now and I am getting ready to do the th350 swap to my 305. I was just wondering if I would need the crossmember that relocates the torque arm? The car came with a 305 and a 200c transmission. The previous owner had a summit crate motor with a 700r4. I am still confused what th350 I need the 9IN truck th350 or the one that came in cars the "short tail"?
Old Mar 27, 2014 | 05:33 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Need some advice on Th350
Do us a favor and go to your user CP and add your car info for future use.....
As for the cross member, If it has the 700R4 cross member now there are swap members available for the TH350 which also has the torque arm mount bracket made on it. That's the best way to go, To run your existing drive shaft you need the 9" tail shaft commonly found in trucks......
Old Mar 27, 2014 | 05:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Restrorob
Do us a favor and go to your user CP and add your car info for future use......
https://www.thirdgen.org/forums/tech...formation.html
Old Mar 27, 2014 | 05:49 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
Would I need this one?
http://www.hawksthirdgenparts.com/pr...ossmember.html
or this one?
http://www.hawksthirdgenparts.com/pr...52d-TH350.html
Old Mar 28, 2014 | 12:55 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Are you using the stock torque arm ?
Read what it says in the description
This is the crossmember only for those who do not require torque arm provisions (ie. 4 link and ladder bar set-ups).
or this one?
This transmission cross-member with integrated torque arm mount features the correct provisions for mounting the TH350 transmission
while still allowing the use of a factory style torque arm.
Old Mar 28, 2014 | 07:28 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
if your handy with welding and fabricating, you can make your own torque arm mount.
another option might be the jegs arm or something similar?
http://www.jegs.com/i/Jegster/550/40095/10002/-1
it might sound silly but when i do drivetrain swaps, i like to measure/draw everything right on the ground next to the vehicle with chalk. it gives me a rough idea of whats going on.
FWIW, i was able to use my factory crossmember when i did the th350 swap. just had to wollow out a few mounting holes. i did use the 9" version tranny.
Old Mar 28, 2014 | 05:13 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
I might be picking up a TH-375 tomorrow out of a 2nd gen trans am. Could I still use my stock cross member?
Old Mar 28, 2014 | 06:33 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i'm no expert, but i believe the th375 is very similar to a th400. if you had the crossmember from the 200r4, sure it would probably fit.
but if your using a crossmember for a 700r4 now, no way.
the th375 is gonna require a much shorter driveshaft too.
heres a chart with dimensions in this link;
http://www.maliburacing.com/auto_tranny_id.htm
Old Mar 29, 2014 | 02:19 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
I will just stick with the th-350. So I wont have to get a new drive shaft. I am trying to keep the costs low.
Old Apr 2, 2014 | 07:21 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
I traded some Parts for a rebuilt th-375. Will I have to cut the drive shaft? Ive seen on some forums that a th-375 is the same length as th350.
Old Apr 2, 2014 | 07:26 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
did you or can you measure the th375 for over-all length, and post the measurement?
Old Apr 2, 2014 | 07:42 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
I can get that measurement for you. I believe its the same length as a th350.
Old Apr 2, 2014 | 07:50 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
did you check out the link in post #8 above? yea, when you get time post the measurement. we'll see what driveshaft you'll need.
Old Apr 5, 2014 | 06:39 PM
xc500's Avatar
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
The th-375 is the same length as the th350 9in tail.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
89newfun
Sep 16, 2015 09:28 AM
